Re-man transfer case, Where?
Looking for good reliable sources to purchase a reman'ed np 241 DHD transfer case. Not looking to rebuild myself, just want to swap. I have searched the net but wanted to see if anyone had some references.
Thanks. |
I have one for sale if your interested, only 15000 miles on it. send me a pm
this is what I need:
29 Spline front input, 31 spline rear slip output, 1.608 OD, w/PTO w/o speedo hole, synchronized, 1.55" exposed input shaft, manual transmission |
sorry this is late. this unit came out of a 2000 auto and is a 241 HD
Another Question- Tag ID
From what I have found searching for transfer case ID you have to use the assembly number. How is that done? I have not been able to find or understand a correlation.
My assembly number is 5210 5027. Help! |
I figured out the Assembly#'s. This is from Alldata.
NP241 Standard Duty 23 Tooth Manual Trans 52105023AC Auto Trans 52105025AB 29 Tooth R2105024 Heavy Duty 23 Tooth Manual Trans 52105026 Auto Trans 52105025AB 29 Tooth R2105027 Replace the R with a 5, misprint by Alldata |
www.certifiedtransmissions.com try these guys out slide down hit transfer case and it asks for the data. or call. dont know where they are shipping from I think calif and colorado. and the other company. is www.transfercases.com
thank you for the first link.
no problem I had these saved on my computer because this is my upcoming next prodject soon. I can do it in the winter where I live it doesnt get nearly as cold as you. good luck post what you end up doing.
