Post your VP-44/LP history!!!
#47
Is there a post on here that will give info on relocating pump to the frame ??
And could the pump be replaced with a say carter 100gph 16psi pump it looks the same maybe with fitting adapters.
#48
Originally posted by newriverSpecon
Some people have had good luck repositioning them to the frame and making them a pusher pump. I personally feel it is heat. But that is JMO.
Randy
Randy
#49
98.5
Original VP-144,000+ uncorrected do to large tire whole life of truck.
1-LP at 100,000
1-CPS changed today only for piece if mind
1-AIT changed today only for piece of mind
Currently using 10liters to 100 kilometers. I think that is aroung 23mpg. Yes I get that minf of fuel mileage. I even haul on the autobahn and still get 18mpg at 90mph.
1-LP at 100,000
#52
01 dodge dually'
1 st 2 were replaced in the winter,with filters changed on time 4th vp on the truck,first at 98,000 warranty which they gave a reman,2nd at 160,000 3rd at 201,000( fall with aftermarket fuel pump) 4th at 220,000(summer w/after market lift pump, all remans from cummins,cost 1350 each, very poor design, need to go back to work
#53
01 2500 Quad
Colorado Springs, CO
1st LP replaced with 2nd LP around 42,000 miles
After 2nd LP started acting funny, I replaced with Carter P4601 on the frame (fine so far after 3000 miles) and 6AN lines from tank to filter inlet
Fuel pressure gauge since 27,000 miles
Original VP$$
Currently at 53,000 miles
Original VP$$
#55
thought:
with the gauge i can monitor the LP to prevent it from keeping hte vp-44 pump cool........can i monitor the vp-44? the LP could be good and the vp-44 pump could be go'n out right?
the LP from the "store" is $200ish...........is it better to buy an aftermarket? if so which and whats it cost?
#56
1ST LIFT PUMP AND VP44 @ 72,000 (REPLACED UNDER WARRANTY) DEC 2003
2ND LIFT PUMP @ 72,003 (REPLACED UNDER WARRANTY) DEC 2003
INSTALL A HOLLEY RED PUSHER PUMP FP @ 16 @ IDLE
3RD LIFT PUMP @ 105,000 ( REPLACED W/CUMMINS PUMP) JULY 2005
STARTED TO SEE SLIGHT PRESSURE DROP W/CUMMINS PUMP FP IS 23 @ IDLE
2ND VP44 @ 108,000 (REPLACED W/BLUE CHIP ) AUG 2005
P2016 CODE, HARD STARTING ISSUE WHEN MOTOR WAS WARM AND SURGING WHEN COLD
#57
02 with 5 speed
The VP shelled out at 83,000 but gave quite a bit of intermittant warning and was running fine the morning I took it in to the shop. Martin Swanty Dodge in Kingman, AZ replaced both the LP and the VP. I've had excellent service from them, it's a work truck and they had it back to me in 1 1/2 days.
My fuel (and other) filters are replaced regularly.
Happened in May, not particularly hot weather.
JTMcC.
JTMcC.
#59
147,000 miles corected to 163k (tires)
original vp and lp
oil psi sender and cam sensor replaced 80 k ish
But the psi is starting to jump and vibrate the gauge buying a cummins lp today
12- idle 7- cruse 1psi 5x5 full fuel
original vp and lp
#60
First time @ 30,000 Mi with 5th wheel @ Yellowstone NP. Trailer in campground, truck broken down on going to the sun road. geting ready to go again dead spots smoke 216.
