Possible rear gear problem?
I've changed the rear end fluid a couple times from dino to synthetic and back to dino with friction modifier and I'm still getting a kind of grinding feel. I don't hear it but I can feel it. Going slow and straight I can barely notice it but around slow turns or going in a circle I can really feel it. I'm also getting a "clunk" from time to time when I make a very slow turn and then let off the throttle quickly. Definitely coming from the rear end area. Any thoughts?
Mark |
Fill the transfer case back up. Seriously though, its probably low or empty. I had a grinding noise and found a leaky tcase.
You might try adding a lot more friction modifier and see if it goes away. You might have an aggressive LSD.
That said, I had a similar-sounding grind in my driveline that went away when I had the Powr-Lok installed. So I think my rear was not setup correctly from the factory. |
I would try to add more friction modifier first. Do some figure 8's in a parking lot to make sure it works in good. I had the same binding feeling when making slow left hand turns.
Ok. Thanks all. I'll pick up some friction modifier and check fluid level in the transfer case too.
| All times are GMT -5. The time now is 07:24 AM. |
