Possible apps problem
Hopefully someone out there can give me some advice. My 2001 HO has started idling strangely. Normal idle was just a hair over 800rpm but now seems to be anywhere between 800 and a little over 1000. I hooked up the Smarty to read codes but all I got was the normal 1693 code. I toggled the ignition 3 times and then got the 0122 code on the odometer read out. (apps voltage low). I should also mention when the truck is idling high a quick jab at the throttle usually brings the idle down. I did a search through the tech tips (what a great forum this is
) and found the apps reset procedure do you think this will rectify the problem. Any help on this would be greatly appreciated. Thanks in advance.
StevenAg03
15
Dec 8, 2008 07:06 AM
smokinram99
13
Mar 18, 2008 10:09 PM
