Plugged fuel filter, but still have pressure at VP??
Old Aug 30, 2009 | 05:59 PM
OldDodgeOwner's Avatar
Noticed I had a fuel leak yesterday. Popped the hood and fuel was squirting out around the o-ring on the top of the filter housing and out the banjo bolt washers on the inlet from the lift pump. I replaced the filter today and no more leaks.
I've got the Edge sender hooked to the VP inlet and an Isspro mechanical guage hooked to the fuel filter housing outlet. Edge was showing 14psi at idle and the Isspro was showing 15.
What I'm confused about is I still had good fuel pressure past the filter, but yet I was still blowing out the seals. What would cause those to leak?
Old Aug 31, 2009 | 12:05 PM
No ideas?
Old Aug 31, 2009 | 12:39 PM
dott's Avatar
Was the old element ripped?
Old Aug 31, 2009 | 03:51 PM
PaulDaisy's Avatar
Had it been ripped there would be no reason for a leak.
Was the pressure reading higher before? If it decreased and leak appeared, the filter just got restrictive enough I think.
What is your lift pump? A stocker I think has a bypass and won't blow seals. If it is a stocker I would think the o-ring just bulged out for some reason. If you had a gauge pre- and post filter you would know for sure. There is a spec in FSM for max pressure drop across the filter, I think 1 psi? I can't recall.
Old Aug 31, 2009 | 04:24 PM
00 CTD's Avatar
Max. pressure drop acroos the filter is 5 PSI.
Old Aug 31, 2009 | 09:29 PM
nitrousn's Avatar
The leak will not be caused by a plugged filter. Loose banjo bolts is my guess.
Old Aug 31, 2009 | 10:20 PM
Nope, the old element wasn't ripped. Grey and dirty, but still intact. Banjo bolts are all tight.
I don't have a pre-filter guage, just 2 post-filter. I have a stock Carter lift pump. Normal pressure at idle with a new filter is 15psi and that's what I was showing on both guages even with the leaks.
The housing was leaking both at the banjo fitting at the inlet and out the o-ring on the cap.
Only thing I can figure is the filter was causing enough restriction, the pump was pushing higher pressure to compensate. How I don't know, I thought they were a constant output pump...
Old Sep 1, 2009 | 09:40 AM
PaulDaisy's Avatar
Bizarre.
Oh well, at least you got it fixed!
Old Sep 1, 2009 | 11:42 AM
Yeah, I'm glad it's fixed. Just really curious what caused it.
031tun
Dec 1, 2012 08:45 PM
trik396
18
Mar 11, 2011 02:57 PM
Rue
Feb 2, 2009 02:43 PM
silverdodge04.5
Apr 20, 2007 04:43 PM
mr T
Feb 24, 2007 06:42 AM
