Part time Hubs DIY.. Parts and tools needed
Old 11-04-2009, 04:05 PM
J OOPS's Avatar
Ford's spindle is also 6 bolt. As for the narrower spindle. It was all about measurements/spacing for the Brake rotor and axle/spindle shaft lengths.
Old 02-17-2011, 06:49 PM
blackimpala's Avatar
Yes it will work
Originally Posted by prattman
JOOPS, Thanks for the write up. Will this work for the '94-'99 CAD Dana 60 front axles? From your poll post, I'm guessing it won't. I just noticed you have a 2002 truck. Awsome work and thanks for sharing you hard work. Regards, Glen
I just completed this mod on my 96 2500. The rotors you will need are from a 78-79 Ford F250 using our Dodge calipers. You will need stub axles from a ford Dana 60 they are 11 1/2" long, got mine from Extream Axle cost $30 each, spindles and hubs from a Ford Dana 50 or 60 The 60 will have more usable parts but will cost more. I had to have my hub turned down to 4.75" so my Dodge rim would fit, re drilled the spindle holes on my drill press. Got all new bearings and races and seals from Rock Auto, don't forget the spindle bearings. Once I had the spindle drilled and turned it was like putting on a kit.
Floyd
Old 02-17-2011, 09:10 PM
caper's Avatar
Does this make your front tires have a wider stance like the EMS and other kits do. This is the only reason I havent done their kits yet , don't dig that at all. Wating for a kit that will keep the fron track with the same as factory. Some pics would be sweet , and approx cost if one was to buy all the items at the parts store.
Old 02-17-2011, 11:19 PM
Tate's Avatar
The track width difference between the EMS and factory is hardly noticeable. EMS uses Ford parts for the conversion, so I would imagine going this route would net the same results.
Old 03-02-2011, 06:20 PM
wthomps's Avatar
I know this thread is a little bit older, but I thought I'd comment on this. The EMS does not use Ford hubs, it uses a hub they make. That being said, EMS track width should be the same as stock. DLX Fab is the one that uses Ford parts and is about 1.5" wider track width. This swap should be comparable to that. It should add a little over 1" to each side. If you used shorter spindles and hubs it would make it track narrower, but then you're going to be doing alot more fab work to make the brakes work and you would need a custom length stub shaft.
Old 03-02-2011, 09:05 PM
Tate's Avatar
The hubs I have definitely look like OEM pieces, they aren't nearly as shiny and smooth looking like the EMS pictures on their site. That being said, my kit is 1.5 years old and things could change. They didn't have their spin tec hubs out when I bought mine. I do have a Ford HP D60 currently in the back of my truck. When it gets nicer, I'll have a closer look and maybe some measurements to see if they are the same pieces.
Old 03-03-2011, 07:12 PM
wthomps's Avatar
Hmm, it could be that the one you have has Ford hubs. I bought a kingpin D60 from the owner of EMS just before he started the business (He's only about 1.5hrs away). At the time he had somewhat developed the free spin kit and was going to try and start selling them. At the time he was using Ford components and was originally targeting Superdutys for the first kits.
Old 03-24-2011, 04:41 PM
Bomer Tom's Avatar
Any one know if using the 78-79 roters would work in this application? like we can don on the older trucks?
like i did in my write up
https://www.dieseltruckresource.com/...n-t287434.html
Old 03-19-2016, 04:07 PM
death row dave's Avatar
AAM Axle DIY
This conversion will not work on AAM axles . Ask me how I know this ! Great write up but not for AAM axle
91oldranchtruck
01-31-2011 09:45 AM
J OOPS
38
04-23-2009 06:33 PM
LJRoy
05-13-2008 05:36 PM
greenwing
05-18-2007 08:58 PM
subspd
08-27-2006 02:17 PM
Quick Reply: Part time Hubs DIY.. Parts and tools needed
