Nub bus, no gauges - mechanical shock I think - Dodge Diesel - Diesel Truck Resource Forums
Notices
Old 03-02-2018, 11:59 AM
Guys,
I haven't been around in a while but it is time to come back for help. I have done some searching and not a lot of diagnosis on the truck yet, that will happen when I return home today. In the interim I was wondering if anyone had any suggestions of where to start.
The first portion of my daily commute is a gravel road. Due to the winter we have had this year it is a very harsh ice and snow washboard. Bad enough that if I go over 20 miles an hour, the cup holder shakes out of the dash. This morning, right at the worst of the shaking from the washboard (right when I expect my teeth to fall out) I heard a bing from the dash. I looked down, all my gauges were dead, No Bus on the odometer and No CCD on the overhead computer. So, I turned off the truck and turned it back on, no difference. At this point I decided to turn around and swap the truck for the car. After about a 1/4 mile the gauges all came back but now the CEL is on. I will check for codes when I get home but my guess is that a connector somewhere got rattled loose by the brutal and incessant banging from the washboard.
Any recommendations on where I should start looking for a loose plug or connector?
Tallguy67 is offline
Old 03-02-2018, 01:40 PM
My no buss, I pulled the cluster and reseated the electrical connectors.
nothingbutdarts is offline
Old 03-02-2018, 02:47 PM
Where is the cluster? I hate to sound dense, but I am not sure where to start looking. Is it firewall, passenger side? I seem to remember that was where I went with my noise filter when my TC wouldn't stay locked.
TIA.
Old 03-02-2018, 03:08 PM
The instrument cluster with all the gauges.
Old 03-02-2018, 03:13 PM
Well heck, that isn't the answer I wanted. Is there an easy way to get to the back of the instrument cluster without spending hours removing the entire dash?
This is the first vehicle I have owned where I haven't had the dash off and on multiple times. Heck, in my Chevy I stopped putting most of the bezel and trim stuff back on
Old 03-02-2018, 06:13 PM
We can close the file on this one for now. Like I said, the gauges were working again by the time I got home. Cleared the DTC’s, went for a drive and no issues.
Old 03-03-2018, 05:55 AM
AlpineRAM's Avatar
The gauge cluster is rather easy to get to- open aux power outlet door (if equipped), remove bolt, pry bezel loose starting at the light switch, go around clockwise.
Then there are only 4 bolts attaching the cluster to the dash.
AlpineRAM is offline
The Following User Says Thank You to AlpineRAM For This Useful Post:
Tallguy67 (03-03-2018)
CORed
27
06-21-2015 01:10 PM
freight train
22
03-25-2013 04:46 PM
WhozNxtLS1
12-10-2008 12:07 AM
stumpjumper
08-21-2007 07:14 AM
camshaw
08-09-2007 01:34 PM
Quick Reply: Nub bus, no gauges - mechanical shock I think
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
