Is this normal?
I assume it is automatic.
Sounds like valve body and steering column are fubarred.
Starts in neutral says neutral safety switch is shorted internally.
Brake interlock is in steering column.
mine does also. theres a plastic piece that holds the release cable for thie shifter when you depress the brake. i broke it removing the dash. it works its just not positioned correctly because the tab broke. could be the same. I dont know how you take the dash out without breaking it
My 2002 starts in Park and Neutral. I can take it out of gear without using the brake. As far as I know all dodge trucks are the same up through 2002 or 2001 on the 1500 models. There was no brake/shifter interlock.
bigbaddiesel
Mar 22, 2003 07:52 AM
tobyw
Dec 11, 2002 11:54 AM
