no start problem
recently my 01 won't start when I turn the key; no cranking; no nothing, after trying 2-5 times it starts, other times it starts right up
no start
I have the same problem with my 06 quad slt. i bought 2 new gold autozone batteries about 6 months ago. drove the truck home the other weekend and parked in the garage on thursday with no problems. sunday when i wanted to start it the voltmeter was just above 11 and nothing would turn, not even a click even though i had the dashboard lights coming on less flashy then usual. i have to figure out what is going on this weekend. i'll let you know my outcome.
Sounds like the starter contacts are about gone. Some searching here will get you lots of info on replacing the contacts yourself and save some $$.
thanks for the input , I'll look into the starter contacts
might be the starter relay if you get no sound at all iff you get a click its your starter contacts
hmmmmm, kinda makes the sound of a loose battery cable when I turn the key, assuming it must be the starter contacts
