No power,Dead pedal
I was driving down the interstate and the truck felt like it missed and the check engine light came on. I had a dead peadel almost felt like there was no turbo. Made the drive 50 miles home and could not pull any hills.Once i got home home i shut the engine off and restarted and the check engine light stayed on. Cheacked codes on dash and found that I have a P1475. Removed the quad from the truck and cleared the codes with a code read and light went off. Then driving the truck it came back. I am also getting a couple other codes now P0237,P0112,P1475,P0563,P0500. What hell happened to this thing???????[verymad]
P1475) CODE SET WHEN (ECM) AUX 5.00V OUTPUT IS ABOVE 5.50V.CIRCUIT IS
MONITORED FOR FAULT WITH KEY ON. I read someone says get the charging system checked out |
