NO brakes!! Put on new pads and calipers
Old 12-31-2009, 07:30 AM
wantinmoresmoke's Avatar
I just put on new pads and was noticing that the both calipers were holding and not releasing all the way. I took both of opened them up as far as they would go and tried it all again the pass side was fine but the drivers was still freezing up. I bought brand new calipers and put them on bled the system and everything but i have NO BRAKES! some one please give some advice is there any secrets i don't know???
Old 12-31-2009, 08:05 AM
patdaly's Avatar
Are the bleeder screws at the top of the Calipers?
Sounds basic, but if they aren't at the highest point you will never get the air out.
Can you pump the pedal and build pressure?
Old 12-31-2009, 03:07 PM
Hodge's Avatar
What are you driving? Knowing what you have, and how old it is, helps out.
If the truck has high mileage, it is work $18 a side to replace the flexible brake lines. They collapse internally, and perhaps you have pushed some debris back into the line, clogging things. Probably not, but it is still a good idea to replace them. When they collapse, they won't allow the fluid to return and take the pressure off the piston.
Old 01-03-2010, 10:02 PM
Ok sorry I forgot the details of the truck before. I have a 2000 CTD 2500 sport ext cab 4wd. It has 200K on it and I just replaced pads and calipers on front. I tried bleeding all 4 corners after having no pressure in the pedal. I believe that the mentioned flexible brake lines are the issue. I will be replacing these as soon as I return from my trip. I was hoping to be driving my Dodge on this trip. oh well. Any other ideas or known issues that I should be aware of?
Old 01-04-2010, 06:21 PM
Hodge's Avatar
When you bled the brakes, did you start with the wheel fartherest from the master, and work to the closest? If not, you could have introduced more air to the system.
Old 01-05-2010, 05:34 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Might have a bypassing master cylinder also. If calipers were seized up most likely had contamination or rust in system. Replace master and flush out brake system with new brake fluid.
Old 01-06-2010, 05:35 PM
grouch's Avatar
Do you have the calipers on the correct side? I worked on an Ambulance once that lost brakes after a repair job. They swapped the calipers from side to side because they looked the same. They are not. Get them on the wrong side and there will be an air bubble you can't get out. With that air bubble you won't have much brake pedal, if any.
Old 01-07-2010, 06:25 PM
Hodge's Avatar
That's right- the bleeder screws need to be at the top.
Old 10-11-2015, 08:54 PM
Gerrygort's Avatar
What are the best calipers to use on a 1999 Dodge Ram 2500 5.9 4 WD
Old 10-12-2015, 08:15 AM
patdaly's Avatar
There really isn't a better brand than another, so long as they are properly rebuilt.
leeboy
09-12-2010 12:46 PM
thesheriff
06-16-2010 07:16 PM
Chip
14
06-21-2009 03:59 AM
LockedandLoaded
13
03-24-2008 12:16 AM
Quick Reply: NO brakes!! Put on new pads and calipers
