New Owner
Hello, i just bought a 99 3500 5spd. 4x4. Im looking for some more info on it. Such as what turbo it has? intank lift pump? h.o. motor? Thanks
If all is stock on your truck, you should have a HX35 turbo.
You more than likely have a NON-HO motor. and havin the intank pump is something you would have to check out. http://dodgeram.org/tech/dsl/mt_2_fe...l_sys_comp.htm Check that out and look to see if there is a pump in the #1 area. If not you have the intank pump.. A fuel pressure gauge would be the first thing I would do if I was you.. |
Thanks for the help
