Need help with ? on LP for 00 2500 4x4 CTD
Originally Posted by lsenus
..........and more "pumping", which is afterall what a pump does. Other wise it would be called a "suck" and not a pump.
I love a great sense of humor.
I concur!!!
I know its confusing ip lp but I hope u will get that straight. The fuel pressure guage is a pretty straight foward proceedure, and it wil probally save u some coin. Mine only tood about 30 min to instalol . PM me if I can help with any info. Give em hell, sorry board monitor for my cursing.( ha ha ha)
Ok, just a little more info on the truck itself. I purchased the truck used, last saturday, from a lot in TN (just outside of Knoxville), also purchased a warranty thru the bank where I financed part of the funds. I live in Indy, so it is not terribly feasible to take back to place of purchase. Would it be sufficient to take it to a Dodge dealer here in Indy? Should I consider taking it to a Cummins shop for service? Also, if this does turn out to be the lp and/or ip, since Chrysler is obviously aware of the problem, (hence the bulletin dated May 2000) shouldnt they be the ones to foot the repair bill?
Is there anything else I could be missing, as far as causes for the dead pedal?
My plan is to install some gauges, but as I said, I've only had the truck 4 days...
Thanks again for all the help, this forum has been a great help already!
Originally Posted by P.J
ALL delaer installed parts come with a 12/12K warranty.
( Dad tried to pay them some on his and they wouldn't take his money
Dead Pedal Fix
Originally Posted by blackenedman
<snip>
<snip>
<snip>
If your problem is this, the service engine light will come on and the code will be P0121. If you get this code, follow the procedure here:
APPS Reset Procedure
If the warranty gives you an option of where you can get it fixed, I would go to a Cummins shop or nearest reliable Diesel shop. Do not put the Dodge Intank pump in your truck. The pump is not strong enough by itself and if you add a pusher to the setup, it has to work harder to get fuel from the intank pump. I have been there and done that.
MikeRP
79
Nov 21, 2016 10:19 PM
Mike D
Dec 16, 2003 04:21 PM
tanderson2002us
Apr 12, 2003 12:34 PM
