Need help locating a tank module
I guess i damaged my module installing the DSV, my gauge reads around 3/4 tank, and it is for a fact alot lower. I could just put a new sender on it, but was wondering if i should just replace the entire module to one that was a pre-in tank pump module. any help would be great.
Well, I would have said yes, because back when I was removing the devils harnesses from peoples trucks, I could buy used modules without the pump on fleabay for 25-35 bucks. Didn't see a single used on on there after looking just now.
It isn't cheap, but perhaps do the Vulcan Liberty module? 300 bucks isn't cheap though. |
I would remove the intank and put in a draw straw and a FASS or Raptor frame mounted pump.
those things are $500 from dealer, vulcan is looking better at 300. may just swap the sender and hope that fixes it all. still think i damaged the sender installed the DSV on it the other day.
