need an expert's help
got a '00 2500 4wd auto equipped with edge w/ attitude, stage 3 injectors and stage 2 afe intake.
having issues in 3rd gear i think when reaching about 45-50 mph. tranny seems to shift early, bog down and keep slipping until i get to about 60mph. tranny was replaced less than 3 years ago.
had the shift timing adjusted about two years ago after 315/75s were put on. everything was great until just recently.
any advice?
any advice?
You should be in OD by the time you are at 45mph. TC lockup occurs at 47mph, if OD is not locked out. The TC lockup will feel like a shift to a higher gear in most trucks, but soft if the TC has not been upgraded. If your TC is slipping in lockup you first need to check the pressures in the transmission. There are test ports you can connect to on the side of the transmission, but you may want to enlist a transmission guy to diagnose this. Tell us your location and we may be able to recommend someone in your area.
Chris
Chris
it feels like its going in and out of OD, like a said right around 50 mph. i guess its a little soft, since it wont stay in OD until i hit like 60 mph. im in san diego, know any affordable experts out here?
sevobuck
56
Sep 29, 2011 08:20 AM
Sevir
13
Feb 14, 2011 11:09 PM
