Need Answers
Hello Guys,
I am asking this question for a friend of mine who has a 98 24v and I do not know much about the 24v's as I am a 12v guy.
So to start things off his truck will not start, but it will crank just not turn over. He has a fASS (not to familiar with those) and says he has replaced that along with a new vp44 IP. Along with these new parts he has cracked the injector lines and the injectors are getting fuel. Now since I drive an complete mechanical 12v I do not know what to do with these electronic controlled fuel systems. When fuel is sprayed into the cylinders is it a huge spray or a trickle? Hard to ask a question like that
First off what does the fASS do?
Any Suggestions on what to look for?
I figure nothing else I will learn a thing or too about the 24v motors
. First off what does the fASS do?
I am not familiar with some of these code numbers, how are you all retrieving the code numbers? On my ole 12v it is turn the ignition on and off three times, is it the same of are you using a scan tool?
Anybody have any ideas?
Thanks
Thanks
If it was running before the new filter, I'd say air in the lines. Make sure to open the 1st 3 and turn it over until fuel comes out. Should crank & run like poo until the rest of the air is purged.
Thanks
When I crank the motor over and see what fuel come out, when I reconnect the the injector lines wont some air get trapped in there?
Don't disconnect the lines. Just crack them open enough for fuel to leak out when you crank the engine over. Once you start seeing fuel, ( ya it will make a mess) you tighten them up and it should chug to life. A lot of times it will try to start even before you tighten them back up again.
VPI
Apr 30, 2004 09:51 PM
