natlchamp2k4 |
04-24-2007 12:54 PM |
Master/slave cylinder problems!!!!
My clutch will stay disengaged long enough for me to put the truck in gear and usually by that time its already taing off on me. Im talking this thing is scarry to drive right now! Ive done some searching and I think its the master and slave cylinders going out. But for some reason could there be some air in the lines. My resevoir was only about 1/2 full so I topped it off. I have not found if you can bleed the slaves on a NV4500, some say just to pump and pump and pump an pump to force the air out. If theres no air and I do that should I see some fluid somewhere, or not? I have read that slves leak externally??
Any help is greatly appreciated.
Jamie
