Map sensor
Old Jan 21, 2009 | 10:00 PM
5.9diesel's Avatar
Map sensor
Wheres it at on a 99 dodge cummins 4x4? i looked for it but couldnt find it
Old Jan 22, 2009 | 02:51 AM
Zeus1987's Avatar
here ya go
http://dodgeram.org/tech/dsl/mt_2_fe...l_sys_comp.htm
Old Jan 22, 2009 | 03:50 PM
5.9diesel's Avatar
I unplugged it. it made the truck real sluggish at first and no smoke. which they said it would do
Old Jan 22, 2009 | 04:19 PM
Maliboost's Avatar
I dont know why it would make smoke. If the computer does not see boost pressure its not gonna add fuel. It should have turned on the CEL. it did on my 99 anyway.
bob
Old Jan 22, 2009 | 04:27 PM
5.9diesel's Avatar
it just made it real sluggish. It turned on my CEL also
Old Jan 22, 2009 | 04:32 PM
stevenl's Avatar
if you dot have some sort of box like and edge comp, or juice, or a power puck even i think it wont do anything, with a performance box on it though it fools the compter into thinkig it is seeing full boost when in fact it is not, so in turn it fuels accordingly, whcih is where the smoke comes from. that CEL will go away after a few drive cycles
Old Jan 23, 2009 | 02:56 PM
tx_2500's Avatar
I cant speak for the puck, but when it comes to Edge products, you can only run the MAP unplugged on the Comp, you cannot do it with the Juice, it will act just like a stock truck (bog down and no smoke)
Old Jan 23, 2009 | 05:55 PM
stevenl's Avatar
really i have seen trucks do it with the juice installed
for more info on this search for threads on something called a "smoke switch" it;ll explain it all and how it works
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
