lower ball joint passenger side 2002- 2500 ram
I'm replacing the tie rod ends and ball joints on a 2002 dodge ram 2500 4x4
Can anyone tell me how to get the pass. side lower ball joint out? Does it take a special tool?
I got the 23pc. kit from Carquest but there is no adpt. that works on this ball joint. Seems that the tool needs to cut at an angle.
Help?
Thanks for lookin
Help?
Thanks for lookin
Had the same problem a while back. $120 kit and still nothing fit it. I think I used a big socket and a big hammer , or it might have been a piece of pipe to span the joint. A lot of yellin helps!
HF has this kit, not sure if one the adapters would work...
http://www.harborfreight.com/ball-jo...cles-4065.html
Wish me luck, I'm starting this project Friday, ball joints, inner and out tie rods, track bar and hub bearing assembly. All moog parts and Timken bearings. 138k on the clock with bad outer side tire wear.
Coaldigger
32
Dec 1, 2019 11:24 AM
marksblaster
Oct 27, 2012 11:26 AM
wcbcruzer
22
Apr 30, 2008 06:58 PM
Common
Apr 27, 2008 12:47 PM
