-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   i raised my lift pump pressure by.... (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/i-raised-my-lift-pump-pressure-36703/)
dvp98.5 Jan 3, 2004 09:57 PM
changing my stock banjo bolt with the ones from genos garage 1-800-755-1715 ask for andy my pressure went from 14 at idle to 15.5 60 mph from 12 to 14 and at wot from 6 psi to no lower than 10 no matter how hard i push it these banjo bolt come in a 4 and 1 kit for the 2000 and up and a 5 kit for the 98.5 and 99 they also sell the westac electric fuel pressure gauge kit for 69.00 i recomend it for all dodge diesels ,well at least the 24 valves these banjo bolts are a lot bigger thanks
tankeryanker Jan 3, 2004 10:39 PM
I just put on a max flow fuel kit from wild cat & a mechanical fuel pressure gauge. Reading 15lbs idle 13lbs cruise 11.5 wot pulling my 12,000lb 5vr. Thanks Rod :D
