-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   How warm is too warm? (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/how-warm-too-warm-211870/)
klx650a2 Jul 22, 2008 04:44 PM
Yesterday towing my 3500 lb dump trailer at 69 mph, my temperature was sitting at about 1/8 inch over the 90 Celsius (194 F) indicator (straight up). The air temp was 32 Celsius (90 F) and about 65% humidity. The a/c was on wide open and I had slight headwind. EGT's were 900 and I was running about 8 lbs of boost. The front of the trailer is low and its a square front, I've relocated the puke bottle and cleaned & flushed the rad. I could hear the fan cutting in as well. I'm thinking of getting a TT and don't want to get to Michigan and have a trailer I can't tow on the highway. I tried towing in 3rd but that made no difference.
Any ideas?
2500Ram Jul 22, 2008 05:46 PM
Did the fan bring it back down to temp?
I need to remove/relocate the puke bottle and clean my rad. I see temps about 1/8" over center pulling our 7000lb TT in the rockies or anytime the AC is running pulling on flat land. Once I hear the fan kick on within a few minutes it's back down to temp and the fan shuts off, hence my lack of a relocation and cleaning job.
Good luck.
Number47 Jul 22, 2008 06:47 PM
all your temps are normal. the fan was going on and off most likely because of the A/C
