How often do you change your oil
Old 09-07-2011, 07:10 AM
Crallscars's Avatar
I have been changing my oil every 5000 miles and filter every 10,000.
I have been told by some I change it too often, and others say not often enough. The truck is usually highway driven, seldom in town.
Old 09-07-2011, 08:20 AM
rebal's Avatar
I change oil and filter @5000 and have for the last 700,000 miles
change your filter too, why dump a quart of dirty oil in with the clean.
jhmo.
Old 09-07-2011, 08:28 AM
Crallscars's Avatar
My oil is fairly clear/clean at 5000 miles, thats why I change filters every other change. I think I am changing oil too often.
Old 09-07-2011, 08:39 AM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
I change every 3,000 miles with a new filter. I know too often right? One of the benefits being a diesel tech.
Old 09-07-2011, 09:00 AM
Dieseldude4x4's Avatar
Every 25,000 miles or two or three years whether it needs it or not.
Old 09-07-2011, 09:07 AM
Purplezr2's Avatar
I don't have an owners manual, but I thought the interval was 7500 severe duty and 15000 standard duty. I change mine once a year, I drive less the 5k a year with my truck as it not my DD
dieseldude4x4, you must have a bypass?
Old 09-07-2011, 09:10 AM
Dual remote system. I ran my 1989 over four years and 60,000 miles with the same system and the oil was still coming back well into the good range. I just hate lying around under a vehicle can you tell?
Old 09-07-2011, 09:49 AM
Crallscars's Avatar
At least with a 4X4 you don't need a creeper to change your oil +1
Old 09-07-2011, 10:25 AM
That's true. I usually change the main oil filter every 5000 and then both at 25,000 so it's not like the same exact oil is in there the whole time. The main filter dumps nearly a quart every time and both take a lot more. Both oil filters are mounted on the front cross member so I can change them in minutes.
Old 09-07-2011, 10:30 AM
Fiftygrit's Avatar
Oil and filter, every 8k miles.
Old 09-07-2011, 11:19 AM
Mike L's Avatar
I go by the book under the severe service recommendations. Oil and filter every 6,000kms and a fuel filter every 12,000kms. Oil and filters are pretty cheap insurance against breakdowns and engine wear. I do my trans and diff oils way too often as well, once per year regardless of mileage. I still feel that oil and lube is cheap insurance. YMMV!
Cheers!
Mike
Old 09-07-2011, 11:21 AM
nkennedy's Avatar
Another once a year guy here. I only put between 5 to 7 K miles a year on the truck.
Old 09-07-2011, 12:16 PM
Doj Dewd's Avatar
oil and filter every 10,000 Km ; fuel filter with every second oil change ; diffs and tranny every 50,000 Km
Old 09-07-2011, 12:23 PM
Move'n Up's Avatar
I run Rotella full Synthetic and replace oil and filter every 5,000 to 5,500 miles
Old 09-07-2011, 02:23 PM
DodgenIt's Avatar
I run mobile 1 for diesels and change oil and filter about every 6 k miles. It's my dd that tows and races with a lot of around town.
Quick Reply: How often do you change your oil
