How much is too much boost pressure?
Old Dec 23, 2002 | 05:40 PM
Wes C's Avatar
???I installed a J-hook to increase boost pressure and am now a bit concerned on how much is too much. My normal guage readings prior to the install read max boost at about 14 pounds. Now I run directly up to 24 on the floor and post turbo EGTs at 950 with no load conditions. Prior EGTs (no load) never exceeded 700 before the J hook install. Normal 55mph EGTs ran at about 450 degrees and now run at +/- 550 degrees. Boost pressure readings were 0-2 at 55mph flat and now stay at 5-6 pounds at 55 mph and run to 14-16 pounds up hills. Any insight on my situation before I do some serious damage would be greatly appreciated. ???
Old Dec 23, 2002 | 06:07 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:How much is too much boost pressure?
Most are seeing 40+ lbs of Boost before head gaskets start going south.
I get 25+ regularly, stock wastgate should be set to around 19-20 lbs.
Old Dec 23, 2002 | 06:13 PM
scottrod's Avatar
My lil hy35 hits 30 at WOT. Hasn't hurt a thing yet ;D
Old Dec 23, 2002 | 08:03 PM
Wes C's Avatar
I appreciate the input! Sounds like I am not going overboard. How about the temperatures? Do they sound comparable/high/low? Thanks again.
Old Dec 23, 2002 | 08:05 PM
Shovelhead's Avatar
Is your Thermocouple/Pyro probe pre, or post turbo?
Old Dec 23, 2002 | 08:14 PM
danlit's Avatar
Try not to make your HY35 go above 30psi after that your doing nothing but blowing extremly HOT air and it WILL raise your EGTs.<br> Danny
Old Dec 23, 2002 | 08:18 PM
scottrod's Avatar
Yeah, thats why I have a PDR HX35 coming ;D
Old Dec 23, 2002 | 08:22 PM
danlit's Avatar
Almost the same ,yours will be about 34 psi before HEAT<br> Danny
Old Dec 23, 2002 | 08:29 PM
98rammer's Avatar
i hit 33 regularly, sometimes 37, and i could hit 40 before i reinstalled my rack stop. the head gasket it still holding. i don't know as you need it to &quot;hold&quot;, i mean that scheid truck was only putting out somewhere around 200psi with the headgasket still &quot;intact&quot; ;D
Old Dec 24, 2002 | 12:28 AM
Roger rodbolt's Avatar
The stock head gaskets on 12v and ETH/HO engines seem to hold less pressure then the ETC. My boost has been running in the low 50's (measured at the map sensor, turbo boost is even higher) for over a year and I'm still on the original headgasket. I've been told that ETC's won't take over 60#'s without oringing though. My experience has been that 40#'s with a stock turbo causes extreme turbo drive/back pressure and is more detrimental then higher boost with a turbo that has lower drive pressures. HTH's Larry
LooseBoltsRob
31
Nov 16, 2007 02:19 PM
rkelley
19
Jan 11, 2007 10:59 PM
MDMIKE
Jan 18, 2005 10:02 PM
NeedMoPower
Jul 12, 2004 10:04 AM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
