How to disable 4wheel abs and not get warning lights.
I am wondering if the resistance in the sensor is causing the issue. If soldering the wires up without the interrupting of the sensor is causing a stronger return to the ecm, maybe signalling the sensor is signalling a fault.
Sorry, kinda tired, but do you get what I am gettin at?
Daniel
I am having a problem making this work. Perhaps I am not understanding what you did. I cut the front four sensor wires and made me two jumper wires from the two rear sensor wires. I then spliced these jumpers into the front wires going into the CAB [Controller Antilock Brakes]. I made sure to maintain polarity plus to plus and minus to minus. When I started my truck the warning lights went out, but when I drove a little distance the lights came back on. I tried this twice and the first time they came on after about 500 feet. The second time they came on after about one half mile. The four wires to the front sensors were unconnected and taped off.
Any suggestions?
Daniel
Any suggestions?
Daniel
So you are saying the light comes on after 500 feet, that would indicate the computer seeing a difference in wheel speed between wheels but you are not getting any codes? Are you checking for codes while the light is on? Yes the battery disconnect will eliminate the codes, will have to be disconnected for an hour or so. I usually turn on lights to make sure system is drained. If the light is out when you first start then there is no code to start with, the code is set when the light comes on. Got me on this one, I am used to diagnosing complete systems so this is a little out of my domain.
Rick.
Rick.
Rick.
Rick.
Daniel
Exactly right on all counts, now to figure it out. If you unplug the rear sensor will the light come on as soon as you start? I am going to assume yes. The sensor is noting more than a magnetic pick up that translates magnetic pulses to electrical pulses, square wave. The faster you go the shorter the square, pulse width. Front and rear pulse width should match for the computer to read that all tires are rotating the same speed, if one is skidding then the pulse width will not match and anti-lock is activated.
I am thinking out loud here to try to come up with a solution, anyone jump in with ideas.
If the two front sensors are tied into the rear sensor then all sensor inputs will be identical hence no activation.
I was thinking that maybe because the computer saw no differentiation in the wheel speeds at all it might see that as a problem but this is too early of a generation for that plus it would have to travel much, much further to trigger that type of a code.
This may sound strange but are you sure the rear speed sensor is good?
The speedometer is fed from a sensor on the transmission. There are two on the transmission, one for the transmission shifting and one for the speedo. Then there are three more for the ABS, the two front wheel sensors and the one mounted on the rear differential. That is the one in question.
The abs on my 99 3500 haven't worked for the past ten years. Something 'Popped" under the hood and the abs quit and the cruise control. When it worked, the computer put me in the middle of way too many intersections and some with a cop watching.
Try this to see if it changes things.
Reconnect the rear to the original wires.
Leave the front two paired up.
The computer can set a cade and not turn on the check engine light.
some code readers don't see all codes either.
My Smarty has found codes that a small shop couldn't find with thier expensive reader.
Daniel
