How did your VP44 die?
Alright fellas, just a simple poll. No comments necessary.
Mine was running fine then one night after work it cut out a few times on the way home. Parked it at home for a couple of hours then when I tried to leave it would start then after about a minute it would idle rough and die. Did this many times until I finally gave up and realized it was the VP.
I'm not sure how to define my failure. I have had 2 VP44's replaced under warranty. One after about 5000 miles and the second at 40,000 miles. Both times the truck ran perfectly but the check engine light came on. I took it to the dealer and he replaced the VP44. The LP has never been replaced.
my truck was running prime and one day i matted it up to about 70 let of and seen all the gauges die.........wasnt cool....bruised my wallet to [verymad]
Mine died a slow death...had a nasty miss at idle, nothing helped, started surging a little at WOT, began to blow white smoke and surge bad under moderate to hard acceleration and a significant loss of power (lift pump was replaced a couple of months before the failure)...never threw a code
Mine had 16lbs or preasure, but the fuel module in the tank failed and it was 16lbs of air no fuel.
I started to get the dead pedal. The dealer replaced the VP44 and did the intank pump. Then I deceided it was time to get gauges. When I first put them in, it read 6 psi at idle and 1-2 on the highway. So I bought bigger fuel lines and a Holley Blue. Now I have 25psi at idle and 16psi at WOT.
Mine was running fine. I was towing and pulled in for fuel. Truck would not start back up. I had no signs whatsoever that it was going out. This was at 6 years and 144k miles.
Monitored Fuel Pressure with a full time gauge since she had 1,000 miles on her.
NEVER under 5 psi while running. Edge Comp for ~ 4 years. (No pump wire) Hooked up pump wire. Ran it for ~ 8 months at all levels. Just died like I'd turned the key off without warning, or a single hiccup while running @ 2,000 rpm down the road on a warm December afternoon. approx 83,000 miles IIHRVP installed in it's place. All good now. |
181264 miles on the stock vp-44 maybe i am just lucky
Originally Posted by hillbillymudrun
(Post 1436676)
Mine died 15 minutes after I installed the Edge Comp.[laugh]
Helped my friend out a few days ago, his FASS system died out on him.
Not really, I had 253,000 on my '99, sold the truck last year and it's still running great. |
Rough Idle :(
Code :o White Smoke [nonono] Dead Petal :( $ 1069 2 1/2 Hour [verymad] |
