Hmmmmm.....
Old Aug 23, 2006 | 11:41 AM
Lurch519's Avatar
Hmmmmm.....
Hey, I have the new Injector pump in, but have not seen an increase of power or fuel mileage . Do these pumps require a break-in time, or was my pump just not all that whacked out ? Isn't the timeing done with the computer and not by an adjustment at the pump ? If an Edge EZ goes bad, will it imitate an IP pump going out ? Sorry for all the questions, but I'm getting a little bummed . Fuel pressure with a new lift pump is 13 at idle, 10 at normal highway speeds and 8 during banzai runs .
Old Aug 23, 2006 | 12:05 PM
graphitecumnz's Avatar
What kind of mileage were you seeing before the IP swap and what kind are you seeing now??
When my IP went, and there was no question about it, I didn't notice a change in my fuel mileage after the swap and didn't expect too. I got 20 when I had a bad IP and still got 20 afterwards even with mods.
As for a "brozen" EZ mimicing a failing IP, I don't think it would. What was the genesis for you swapping pumps??
Old Aug 23, 2006 | 05:36 PM
TNfarmboy's Avatar
For what it is worth..... I just bought a 98.5 24V and found the LP bad. Performance was less than what it should have been also. Put in a walbro and expected (hoped) to see performance return... it didn't I was begining to think it was the VP too! I got to looking and found the waistgate actuator diaphram leaking Read a lot of post, and tech articals and fixed it with a spring from the hardware store Runs much better for now (key word).
Old Aug 23, 2006 | 06:31 PM
Lurch519's Avatar
I got two codes ( p1698 and p0213 ), the dealer said it was bad and needed replacing . Talked to my mechanic and he said it was probably bad but might last a year or go out the next time I started my truck . I thought to replace it at a time of my choosing instead of on a trip or something . Murphy's Law ya know .
westcoaster
Jul 27, 2010 09:39 AM
Homestead
Oct 29, 2008 03:02 PM
runamuk
Sep 13, 2006 04:12 PM
admin
Jan 7, 2003 05:38 PM
