Help with Throttle/Pedal Position Sensor - Dodge Diesel - Diesel Truck Resource Forums
Old 01-26-2018, 07:15 PM
Rufus's Avatar
Hi Guys,
I had to replace the intake heater relay on my 01 2500 Diesel (24 valve) the other day, and when we cleared the code, another pulled up. This time it's the Throttle/Pedal Position Sensor/Switch B Circuit Low Input. The code reads out,PO222 but I found that it is really PO2122. Reading the threads on this subject, I see it's an APPS rather than aTPPS.
How do I determine if it is the sensor, or the connection?
Could I have fouled the connection while I was rooting around with the intake relay?
BTW, the truck seems to be running just fine, but the engine light is still on.
Any information you all can give will be appreciated.
Thanks
Have fun
Rufus
Rufus is offline
Old 01-27-2018, 10:19 AM
Dieselbuilder's Avatar
We have a APPS not a TPPS
Dieselbuilder is offline
Old 01-27-2018, 07:10 PM
Originally Posted by Rufus View Post
Hi Guys,
Thanks
Have fun
Rufus
Quick, order your Timbo APPS now and keep it until you need it or just change it out now, it will save you a bundle of money and a lot of hassle.
Busboy is offline
Old 01-28-2018, 12:18 PM
SIXSLUG's Avatar
On an 01 with 115K you are probably due for a new APPS. I put a timbo on mine back then and its a non issue.
I didn't have a code, just an odd miss at any steady speed....
SIXSLUG is offline
jeramy125
07-01-2009 09:46 AM
cwg
04-14-2009 08:38 PM
swktk1
06-26-2005 10:23 PM
tishmael
09-01-2003 12:49 AM
tishmael
13
12-02-2002 01:39 PM
Quick Reply: Help with Throttle/Pedal Position Sensor
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
