Help Oil Leak
Hello Everyone When Looking At Truck Under Hood Drivers Side Front Of Motor Kinda Next To Fan Thiers A Little Canister With A Hose On Top Of It Seems To Be Comming From Thier Can Any One Help Me Out Thanks For Your Time 2002 Dodge 2500 24 Val Diesel I Have To Go To Work Soon But Will Check Back Latr Thanks Again
Originally Posted by dodge 24
(Post 2190023)
mishkaya |
Thanks Mishkaya Very Much Will Try Should I Also Clean Out The Hose
(Post 2190035)
mishkaya |
Thanks Again Mishkaya Will Def Do It Next Oil Change
You don't need to wait until the next oil change to empty the bottle, especially if it's full, it's just a good thing to do every oil change to make sure that it does not overflow and leak everywhere. You should also check the engine side of your radiator to make sure it's not gunked up with oil. You will know if it is when your engine starts overheating (not good). Many have sprayed simple green on the engine side of the radiator and rinsed it off with a hose to remove some of the crud. You can do a vent relocation search on this site and find plenty of options as to what you can do to eliminate this problem.
mishkaya |
