hard start help
hard start help
ever since I got the vp44 replaced and new injectors the truck has never fired right off, before this it always did
the pump and injectors , big line kit , draw straw, frame mounted lift pump, new cummins engine ecm with all dodge updates installed at the time by dodge dealer, were all done same time several years back and the actual shut off issue then was not the vp44 but a bad fuel sender saying I had 1/4 tank at empty
the vp44 and rv275 injectors were fro pensicola diesel , this work was performed at a cummins certified shop, like I said its been a long time butover time the hard starts gotten to the point that I found that im losing prime in the system
from cold start if I bump the key it will run 20 psi on the fuel gauge, crank the hell out of it and it will finily start and run rough for a few seconds chugging white smoke then smooth out, I am guessing this is the air bleeding from the injectors
when running I also hear an intermittent miss at idle that's always been there since the vp44 and injectors were done
I added a anti backflow between the tank and lift pump, and unhooked the e z edge for good measure
the truck sits a lot since 2009 but only recently has gotten this bad
I have a new fass pump but don't want to throw it on if I don't need to, once running the trucks fine
I also did find the banjo bolt on back of head loose along with the fittings at the t on the return line at rear of block
i do get a stuck injector pump code , and when i shut it off and turn key on i can watch the fuel gauge go down pretty rapidly
any help would be great as i cant afford to randomly throw parts at this or pay a shop endless diagnosis hours that i can do myself
There was one time I was getting that type of problem and it turned out being the cover on my vp-44. Technically, I think you're supposed to replace the whole vp44 because it's "not repairable'..However,.. I think I just used RTV silicone (been a LONG time so I don't even recall exactly what it looks like) and that fixed it.
One thing I must mention,.. About a year ago I changed my fuel filter setup to the earlier one that takes a screw on fuel filter that looks like an oil filter.. It has behaved MUCH better since then. When I changed my lift pump,..I no longer had to open an injector and crank it to get it running,.. When I change the fuel filter...I no longer have to crank the motor with an injector open to get it running. If I had ANY idea how much better the older style was I would have done it the day I bought the truck.
Unhooked the batteries, load test on pass side dropped from 12 to 8 volt, drivers side from 12 to instant 0 volts
2. New batteries today and fired right up, i am not convinced this is the only problem but im sure its a big part
nothingbutdarts (07-23-2017)
Sarajaye
11-21-2014 06:14 PM
