Grease points
Can anyone tell me where the grease points are on my truck? I was under there yesterday and only found 3. The 2 upper ball joints(1 on each side) and 1 on a steering arm on the drivers side. Any help would be great.
I only have two both on the steering arms.
3 is all I have.
Thanks, Guys I thought for sure I was missing some.
I think there's one on the track bar, left side of truck, unless that's one your counting on the steering.
Unless you've had the need to change any of the U-Joints the factory ones do not have any fittings. Just replaced the rear on my '01 (@78K) and the new one (not from the dealer) actually has one. One of these weekends when my honeydo list is a lot shorter I'll get around to replacing the other two on the rear shaft.
Dave |
Fschiola, Your right about the track bar. My terminollogy is pretty bad. thanks CJ
Originally posted by CJ Fschiola, Your right about the track bar. My terminollogy is pretty bad. thanks CJ |
My 98.5 has 6 or 7, Raing out, and will not ckimb under to check
When i had to replace all the steering linkages on my 01 at 60k miles i put grease fittings in all of them. I now have 200k miles and they are all still in good shape.
They are cheap to begin with and not having any fittings even makes its worse. Jason |
| All times are GMT -5. The time now is 01:35 AM. |
