Gear ratios
Old Dec 5, 2006 | 04:34 PM
Krob's Avatar
Gear ratios
Alright im looking at buying a new (to me) rig. Ive looked at a number of rigs and have been told about several over the phone. I keep coming up against the same problem, people are telling me that the trucks have 3:73 in them. I was told by some one here that 02 and older years dont have them just 3:5_ and 4:10 but i keep on getting told that a trucks got 3:73.
Right know im most curious about 02s and if thats possible because im going to go look at one 100miles away and the guy is telling me positivly that they are 3:73 i dont want to make the trip though to find out that they are 4:10s and that the guy was all jacked up.
Anyway i hope i wasnt rambling thank you
Old Dec 5, 2006 | 05:06 PM
Tate's Avatar
Get them to check either under the hood, or in the glovebox. It will tell you what axle, ratio and if its a posi or not.
Old Dec 5, 2006 | 05:21 PM
CTD NUT's Avatar
As we discussed in a past thread, 2nd gen CTD's were only available from the factory with 3.54's or 4.10's. It is perfectly possible that the previous owner installed aftermarket 3.73, though, it isn't likely. The build sheet on an 02 will be in the glove box but it will only say 3.54 or 4.10.
All 3rd gens came either equipped with the 3.73 or 4.10....this could be causing some confusion?
If a gear swap has taken place by the previous owner, the ONLY way to be absolutely certain what gears were installed is to remove the diff cover and observe the ring and pinion tooth count that is stamped on the side of the ring gear.
Old Dec 5, 2006 | 10:32 PM
Krob's Avatar
I didnt want to seem like i didnt believe you i was just cheking because this is the fourth truck by three different people 02 or older that ive been told they have 3:73 in them and most of my looking has been over the phone saving me hundreds of miles driving. So i dont mean to offend you if i did.
Old Dec 5, 2006 | 10:38 PM
Krob's Avatar
I know on my rig in the glove box that it a series of numbers what numbers would i be looking for to know gear ratio and what kind of re end it has (posi etc). Thanks for all your help.
Old Dec 5, 2006 | 10:58 PM
torquefan's Avatar
On 2nd gen trucks, the ratio is stamped on the tag on each diff cover. If it has limited slip, there MAY be an additional tag saying Use Limited Slip Additive. You won't find this info on the glovebox or door sticker unless it's a 3rd gen. Some trucks MAY have it on an underhood sticker.
If you can get the truck's serial number, you can get a Dodge dealer to run it through their computer to get a build sheet (option list). They may get tired of doing this if you have 4 or 5 different trucks to look at. I believe they will do this on the Dodge website, but it takes several days.
Old Dec 5, 2006 | 11:08 PM
displacedtexan's Avatar
There is also a tag on the underside of the hood that says the gear ratio. Not sure off hand if is sayd LS or not. But it does say gear ratio in plain english. No numbers to decode...
Old Dec 6, 2006 | 12:04 AM
Krob's Avatar
Alright thanks for the fast replies. Unless the guy sells the truck im going tdown to see it on Saturday.
Old Dec 6, 2006 | 06:43 AM
CTD NUT's Avatar
Someone please correct me if I'm wrong but I don't think the 02's have a build sticker on the underside of the hood - it was relocated to the glovebox....I think the location was changed in 00 or 01? As Displacedtexan mentioned, this sticker says in plain english what the ratio is and there is nothing to decode. Again, this info is a moot point if a gear swap has been done.
Old Dec 6, 2006 | 06:59 AM
I don't know if the 02's have it. I know it was there untill 99 at least...
Old Dec 6, 2006 | 12:32 PM
hamilton71801's Avatar
My 01.5 is in the glove box.
Old Dec 6, 2006 | 12:40 PM
Mcmopar's Avatar
If I remember the "order code" for the "anti spin" is DSA.
Old Dec 6, 2006 | 05:47 PM
ib516's Avatar
On my 2002, there's a sticker in the glove box, says 3.54 and anti-spin. No code deceiphering required.
3.54 and 4.10 are the only ratios offered by the factory in the 2nd gens.
Old Dec 7, 2006 | 09:07 AM
RowJ's Avatar
My used 02 had neither... under hood or glove box.
Get VIN # and go to dealer. 'Build Sheet' with list of factory options should only take parts dept. 30 sec to produce! My dealer did it for free.
RJ
Old Dec 7, 2006 | 03:42 PM
Red3quarter's Avatar
My 2002 has it in the glovebox, my 95 was under the hood.
