Fuse pannel or ignition switch problem?
2001 RAM 2500 diesel 4X4 manual:
50% of time when I start truck, the following will not work: air cond, horn, speedometer, electric windows. I then go pull fuse #12 ? and that kills the engine. I replace the fuse and start the truck again and 50% of the time all will work except the right electrinic window. If upon restarting the truck the above stuff noes not work, I pull the fuse and put it back in and keep pulling and replacing until they work. Is this the fuse pannel or ignition swithc or what? I can not take to dealer because the truck in Nicaragua and there is no dealer. Help please |
Did you check the main connection at the power dist center ? It comes straight off the battery. Clean thoes real well also clean fuse contacks.
Where are you in Nic? I have been a few times on mission trips. |
| All times are GMT -5. The time now is 04:31 AM. |
