Front caliper brake slides question
The other weekend , I had to change rotors on my 99. Luckily I remember someone explaining the trick to use the power steering to get them off I changed pads as well. The caliber bolts came out fine but those slides inside the rubber pretty much took a big hammer to knock them out . I sanded them down and cleaned them up . Lubed them with high heat brake slide grease and one of them still took a hammer to smash back in . So my question.... are the rubber seals and slides shot? Is it time to replace the seals, slides and bolts perhaps ? Thanks
You will need to pull the rubber part, and remove the rust that has formed between the caliper and the rubber.
Normally there is no need to sand down the slides except for cleaning them.
The rust forms in the hole where the pin boots sit, and since the rust is much bigger than the steel it comes from the pin boots get compressed to a diameter that makes the slide pins stick in them.
I prefer to coat the holes in the caliper with a very thin layer of caliper paint after removing the rust. But you'll need to let the paint dry really good before reinstalling the boots, else the paint will glue them to the caliper.
HTH
HTH
The following 2 users liked this post by AlpineRAM:
leeboy (09-01-2017),
nothingbutdarts (08-30-2017)
Thanks for the explanation and the diagram . Last question I have about this is , is it important for the steel sleeve ( not the bolt ) to slide easily back and fourth inside the rubber boots or is the sleeve just acting as a guide for the bolt ?
leeboy (09-01-2017)
HTH
HTH
leeboy (09-01-2017)
archer39
11-09-2009 09:29 AM
