Front brake calipers on a 2001
Old Dec 13, 2004 | 12:22 PM
Palmetto_kid's Avatar
I think I need new brake calipers.
I changed out my brake pads the other day after on 8 months of use on them. They usually last me longer than that. I think one side is sticking.
Every morning when I get ready to leave for work, I back out of the driveway, and the first time I hit the brakes it feels like they are locking up. ITs like a sudden slam of the brakes, but i am barely putting pressure on the pedal.
I will be doing this job myself, and I have never disconnected a brake line before. So any suggestions on bleeding brake lines, or putting them back together would help. Also, how much do these rebuilt calipers cost?
Thanks!
Phillip
Old Dec 13, 2004 | 12:59 PM
BigBlue's Avatar
The rebuilts from O'reilly's are $66/piece. I'm wondering if I need new ones cause I have to replace my pads once a year (had to since I've owned the truck) and I don't tow. Have you ever noticed one of the pads wearing quicker than the other one?
Old Dec 13, 2004 | 01:05 PM
yes. the driver side was allot worse. It actually cut into the rotor a little, and I had to get it turned.
Old Dec 13, 2004 | 02:55 PM
BigBlue's Avatar
Ok. On the driver side caliper, was one of the pads worn worse than the other?
Old Dec 13, 2004 | 03:20 PM
oh yeah. The inside pad seems to be worse on both wheels. I think that is because that is the side the piston is pushing on, but I could be wrong.
Old Dec 13, 2004 | 03:28 PM
amartinson's Avatar
It is normal for the inside to wear faster than the outside, even if the slides are working properly.
If the drivers side is worn considerably more as you say, you probably do have a caliper problem. Unfortunately, the proper method is to never replace one caliper IMO. They should always be replaced in pairs.
Pretty straight forward job. Since you have done brake jobs in the past, you should have no problems.
Consider replacing or upgrading your front brake hoses as long as you are at it. And of course, bleed the system until you have fresh fluid coming out the bleeders.
Old Dec 13, 2004 | 03:37 PM
Sounds good. Thanks for the input.
Old Dec 15, 2004 | 06:50 AM
Stamey's Avatar
When you get under there with that caliper, could you measure between the bolt centers on the caliper adapter for me? I'm talking about the part that actually bolts to the steering knuckle (the caliper is then bolted to the adapter). I'm engineering something and need to know that measurement.
Thanks,
Chris
Old Dec 15, 2004 | 07:39 AM
Ill try my best. Dont we have a different setup though?
Old Dec 15, 2004 | 08:40 AM
amartinson's Avatar
YES!
Old Dec 15, 2004 | 09:44 AM
Idaho Guy's Avatar
Re: Front brake calipers on a 2001
Are you sure it's the front brakes that are grabbing? My truck has this same problem every morning but it's the rear brakes that want to lockup. See this thread. I always drive off going forward, though, so I've never noticed if it does it backing up. Just wanted to throw that out there - might save you $120 on changing out a couple of calipers if it's not needed.
Old Dec 15, 2004 | 06:07 PM
Stamey's Avatar
Yes, it is a different setup, unless I have my way.
That's why I need someone with a 2000 or newer to measure those bolt centers.
Thanks,
Chris
Huntindad
Jan 26, 2014 02:44 PM
3J1&3J2Bill
Feb 15, 2011 04:39 PM
Bobcat698
Apr 1, 2007 10:26 PM
jriggs_18
Aug 25, 2006 12:20 AM
rob-dude
Nov 17, 2005 04:28 PM
