Engine won't crank
Ok, I got everything back together... I think. Turn the key but not much happened...no cranking. The lift pump sounds very weak but I'm thinking that is just air in the lines.
Also, when I first turned the key on I rolled the windows down... but now they won't go back up. So I don't know what's going on... but it's late, I'm tired, and whatever it is can wait 'til morning. Any ideas on where to start looking? ~ Russ |
Batteries are new and I cleaned/sanded all the grounds before hooking them up.
crank
try using jumper cables , jumping the ground side 1st ,from battery to starter body , try key ,if no responce then jumper wire at solinoid ing. wire to batt. +, if no responce then jumper cable batt.+to cable on solinoid try key , if still no responce then start over ,load test batteries .
My brother pointed out a blown fuse... just needed a fresh set of eyes.
Happens to all of us, we're here when you need us. [director] [dummy]
Glad you found it....
