Engine Troubles
Old Jul 23, 2015 | 09:22 PM
20012500dodge's Avatar
Engine Troubles
I am getting A P-1690, P-1694, and P1693. I know the 1693 ends up being the Maps sensor. I replaced it about a month ago. The 1690 is a communications error between the injector pump sensor and the engine sensor. There are a lot of variables to consider when reading possible fixes. Is there a most common problem I can start with before heading to the injector pump with this? Thanks in advance for all help.
Old Jul 24, 2015 | 08:21 AM
patdaly's Avatar
P1693 is a companion code, you need to read the other computer to see what that code really is.
I am betting it is a VP related code such as P1688 or 89.......
For good diagnosing info on the VP, go to bluechip diesels site, best info on the VP I have seen.
Old Jul 25, 2015 | 08:21 AM
Yes the 1693 is a companion. The code pulled from the OBDll is the 1690 code.
20012500dodge
Jul 24, 2015 06:50 AM
stock600
20
Apr 15, 2008 09:19 AM
fletcher359
Dec 19, 2007 09:58 AM
mtedwards
Mar 15, 2007 10:59 AM
GotBoost?
20
Jan 17, 2005 07:50 PM
