Engine codes
All this talk of engine codes latley got me to looking at my rig. I went and used the ignition to get the codes and now I'm confused. :-[ Here are the codes 0500, No VSS signal, 1693, DTC detected in companion module or DTC detected in PCM/ECM and 0234, Turbo Boost exceeded.
Now I can probably see the 0234 but I have a boost fooler. The other codes I'm confused, what do they mean and what is wrong? Any help is appreciated!! Thanks, Kimrey |
Re:Engine codes
Take a look here:
http://www.troublecodes.net/chrysler/ |
Re:Engine codes
Billg, I did, that's where I found what the codes said, but what do they mean? What's wrong with my truck, what can I do to correct that? Thanks for the response, I thought there were more people out there that knew what all this meant?
Kimrey |
Re:Engine codes
0500 no speed sensor signal....does ur cruise control work and ABS
the DTC code seems like it is just telling u that there is a code that wasnt expected because everything seems to be working properly also if u have no check engine light these could be history codes... |
Re:Engine codes
P0016 Crankshaft/Camshaft Timing Misalignment/Out-of-Sync
P0071 Ambient Temperature Sensor Performance / Rationality P0072 Ambient Temperature Sensor Low P0073 Ambient Temperature Sensor High P0088 Fuel Rail Pressure Too High P0106 Manifold Absolute Pressure Sensor Performance / Rationality P0107 Manifold Absolute Pressure Sensor Low P0108 Manifold Absolute Pressure Sensor High P0111 Intake Air / Charge Temperature Sensor Performance / Rationality P0112 Intake Air / Charge Temperature Sensor Low P0113 Intake Air / Charge Temperature Sensor High P0116 Engine Coolant Temperature Sensor Performance / Rationality P0117 Engine Coolant Temperature Sensor Low P0118 Engine Coolant Temperature Sensor High P0128 Cooling System Error / Thermostat Rationality P0148 Fuel Delivery Error P0169 Water-in-Fuel Detected For Too Long P0192 Fuel Rail Pressure Sensor Low P0193 Fuel Rail Pressure Sensor High P0201 Fuel Injector 1 Circuit P0202 Fuel Injector 2 Circuit P0203 Fuel Injector 3 Circuit P0204 Fuel Injector 4 Circuit P0205 Fuel Injector 5 Circuit P0206 Fuel Injector 6 Circuit P0217 Coolant Temperature Too High P0219 Engine Overspeed P0234 Turbocharger Overboost Condition P0236 Turbocharger Boost Pressure Sensor Performance / Rationality P0237 Turbocharger Boost Pressure Sensor Low P0238 Turbocharger Boost Pressure Sensor High P0251 Injection Pump Fuel Valve Feedback P0300 Multiple Cylinder Misfire P0301 Cylinder 1 Misfire P0302 Cylinder 2 Misfire P0303 Cylinder 3 Misfire P0304 Cylinder 4 Misfire P0305 Cylinder 5 Misfire P0306 Cylinder 6 Misfire P0335 Crankshaft Position Sensor Circuit P0336 Crankshaft Position Sensor Performance P0337 Crankshaft Position Sensor Circuit Low P0338 Crankshaft Position Sensor Circuit High P0340 Camshaft Position Sensor Circuit P0341 Camshaft Position Sensor Performance / Rationality P0381 Wait-to-Start Lamp Inoperative P0461 Fuel Level Sensor 1 Performance / Rationality P0462 Fuel Level Sensor 1 Low P0463 Fuel Level Sensor 1 High P0477 Exhaust Pressure Control Relay Low P0478 Exhaust Pressure Control Relay High P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay) P0483 Cooling Fan Speed P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1 P0514 Battery Temperature Sensor Performance / Rationality P0516 Battery Temperature Sensor Low P0517 Battery Temperature Sensor High P0521 Oil Pressure Sensor Performance / Rationality P0524 Oil Pressure Too Low P0532 A/C Pressure Sensor Low P0533 A/C Pressure Sensor High P0541 Intake Air Heater Relay 1 Low P0542 Intake Air Heater Relay 1 High P0562 Battery Voltage Low P0563 Battery Voltage High P0572 Brake Switch 1 Low P0573 Brake Switch 1 High P0580 Speed Control Multiplexed Switch 1 Low P0581 Speed Control Multiplexed Switch 1 High P0602 Control Module Programming Error/NotProgrammed P0604 Internal Control Module RAM Integrity Failure P0606 Internal ECM Processor P0607 ECU Internal Performance P0622 Generator Field Control Circuit P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High P0630 VIN Not Programmed in PCM P0633 SKIM Key Not Programmed in PCM P0642 Sensor Reference Voltage 1 Circuit Low P0643 Sensor Reference Voltage 1 Circuit High P0646 A/C Clutch Relay Circuit Low P0647 A/C Clutch Relay Circuit High P0652 Sensor Reference Voltage 2 Circuit Low P0653 Sensor Reference Voltage 2 Circuit High P0698 Sensor Reference Voltage 3 Circuit Low P0699 Sensor Reference Voltage 3 Circuit High P0700 Transmission Control System (MIL Request) P0837 Four Wheel Drive (4WD) Switch Performance / Rationality P0838 Four Wheel Drive (4WD) Switch Circuit Low P0839 Four Wheel Drive (4WD) Switch Circuit High P1652 J1850 Communication Bus P2121 Pedal Position Sensor 1 Performance / Rationality P2122 Pedal Position Sensor 1 Low P2123 Pedal Position Sensor 1 High P2127 Pedal Validation Switch 2 Low P2128 Pedal Validation Switch 2 High P2146 Fuel Injector Group 1 Supply Voltage Circuit P2149 Fuel Injector Group 2 Supply Voltage Circuit P2266 Water in Fuel Sensor Circuit Low P2269 Water in Fuel Condition P2502 Charging System Output Voltage P2503 Charging System Output Low P2504 Charging System Output High P2509 ECM/PCM Power Input Signal Intermittent P2607 Intake Air Heater Relay 2 Low P2608 Intake Air Heater Relay 2 High P2609 Intake Air Heater System Performance |
Re:Engine codes
DTF5152, So there is nonthing to worrie about, right? Cruise works great, ABS, I guess it works. Haven't had to use it lately ;). I did replace my brake fluid a while back. As far as the other DTC codes, there is no worrie right? If you have any more ideas let me know. Thanks for the help!
Kimrey |
Re:Engine codes
Have you tried to remove the Van-Akken box to see if any of them go away? Just curious what happens if you have.
Re:Engine codes
Jack, I haven't. I thought once the codes were there, they would stay until you reset the computer. I was understanding that you can un-hook the batteries for 20 minutes and it would reset the computer. I will try that over the next few days. Thanks,
Kimrey |
Re:Engine codes
Some codes clear that way and some clear after several starts without the condition that caused the code. Others will have to be reset by a code reader. If you know someone with a supperchips programmer they can read and reset them for you. You can also go to some auto part stores (Advanced Auto, Auto Zone) They will sometimes read and reset the codes for free.
Hope this helps. |
Re:Engine codes
[quote author=Kimrey link=board=4;threadid=22934;start=0#msg214991 date=1069970305]
All this talk of engine codes latley got me to looking at my rig. I went and used the ignition to get the codes and now I'm confused. :-[ Here are the codes 0500, No VSS signal, 1693, DTC detected in companion module or DTC detected in PCM/ECM and 0234, Turbo Boost exceeded. Now I can probably see the 0234 but I have a boost fooler. The other codes I'm confused, what do they mean and what is wrong? Any help is appreciated!! Thanks, Kimrey [/quote] I have had the same codes that you listed. 0500 I got from spinning the tires too much (driven on ice or snow lately?), 1693 is a companion code that doesn't mean anything other than there is another code set, and 0234 is the overboost. My EZ wasn't hiding the boost, so I sent it back and they sent me a new one and I haven't had a problem since. |
Re:Engine codes
willyzao, Maybey when it rained last time ;) My van-akken box did not come with a boost fooler. I bought it seperate. It's a small box about the size of a small box of matches, and plugged it in the harness. The truck still has power above 20# of boost. I thought if the computer read over boost it wouldn't fuel anything above 20#? Now I'm really confused. So with the boost fooler it's not supposed to throw a code?
Thanks, Kimrey |
Re:Engine codes
I've lost my instructions for the ignition code test. :'(
Could someone please point to the thread. Thks, CR |
Re:Engine codes
All I do is turn the ignition on three times ( Don't bump the starter ) and look at the odometer display and it show you the codes.
Kimrey |
Re:Engine codes
[quote author=Kimrey link=board=4;threadid=22934;start=0#msg216554 date=1070312199]
willyzao, Maybey when it rained last time ;) My van-akken box did not come with a boost fooler. I bought it seperate. It's a small box about the size of a small box of matches, and plugged it in the harness. The truck still has power above 20# of boost. I thought if the computer read over boost it wouldn't fuel anything above 20#? Now I'm really confused. So with the boost fooler it's not supposed to throw a code? Thanks, Kimrey [/quote] I take it you have an older VA, I think the new ones come with a boost fooler built in. Any boost pressure over a certain psi (19 or 21) is intercepted and 'chopped' by the fooler so the truck's computer only sees normal boost numbers. You probably won't notice much of a difference unless you pay close attention to how the truck responds after you clear the code. This thread will explain it better: http://www.turbodieselregister.com/f...threadid=86752 My EZ wasn't fooling anything, so I sent it back, they sent me a new one and I cleared the code; the difference was amazing. Just make sure you clear the code before any warranty work is done, that's an automatic red flag at the dealer. I've heard the 0500 will clear itself, so spin away ;). |
Re:Engine codes
Willyzao-
You say 1693 is a companion code? It's the only one my truck is showing, so I don't think I have any others set... I've got another thread going -what's up with my truck. Any ideas? Sorry to hijack the thread, but I need this truck for work. Thanks, AUstin |
| All times are GMT -5. The time now is 04:35 AM. |
