Emergency Brake Cable Question
Old Mar 4, 2012 | 05:49 PM
Kirk T's Avatar
Question Emergency Brake Cable Question
Replacing the emergency brake cable on a 2000 Ram 2500 with drum brakes. I have a OE cable. It did not come with a spring on the portion on the brake shoe side of the backing plate. The spring on the original cable has ends on it small enough the bead on the cable will not allow the spring to come off the original cable and go on the new one. Is the cable I have the incorrect one or is there a trick to swapping the spring to the new cable.
Old Mar 5, 2012 | 02:30 PM
horselady's Avatar
I changed the cable on my truck, we just had to pull hard and the spring came off
Old Mar 6, 2012 | 09:03 PM
Kirk T's Avatar
Thanks for your responce! I'll try that. It has to come off to remove the damaged cable, the spring wont go thru the hole in the backing plate!
Old Mar 10, 2012 | 12:08 PM
Kirk T's Avatar
Just a follow up. You were right! Ipulled hard and it came off. Thanks
Kirk T
Mar 5, 2012 11:11 AM
samiam4
Jan 15, 2012 05:56 PM
jdgreen
Oct 19, 2009 08:24 AM
jimbo486
Jul 6, 2009 11:23 PM
banzaitoyota
Aug 6, 2006 02:14 PM
