Dtc p pcm?????
I been searching for a few hours and cannot find this one?????
P PCM is the code that I am getting???? |
What are you using to pull codes? Maybe check code reader with another vehicle to make sure its not the reader. If it's fine maybe check for 5v at the OBDII connector, not sure what "P PCM" would mean.
Maybe P PCM is just a header to tell you the codes which follow are from the PCM, but no codes follow so none are stored.
