DTC codes P0234 and P1693
Anyone know what these codes are and any need to panic? They popped up after a few months of using a Hypertech programmer on stage 3, could be totally unrelated though...
P1693 - Telling there is errors in ECU and/or PCU.
I would remove all programming youdone back to stock and then take the truck to the dealer and show them the code by using the key trick. They will most likely replace the turbo charger.
Or...
You can clear the codes and see if the come back if they do I would go to the dealer...
Or...
One more thing, please explain to me how/why I'm loosing power and what's going on mechanically, thanks man!
As for the dealer fighting it... Well if he starts sniffing around and finds tell tales for BOMBS like the software modification, chip box etc... The might drop you like a hot rock. But if you return you programming to stock they might not say anything and replace the turbo under warranty. Being the warranty is still active.
Just point out that there is a error code P0234 using the key on/off trick. They cannot fight that... But if you use you programming box to show that well... Don't expect them to be to helpful...
I hate to keep buggin' ya but what's the "key trick"?
http://www.frontiernet.net/~mopar197...rror_codes.htm
So I have a question related to the wastegate not working and giving an 'Overboost' condition. Can you not just replace the WG valve? Seems simple enough to me.....besides I just found mine is leaking!
