Dreaded P1694 code
Old Oct 19, 2008 | 02:46 PM
daboocru's Avatar
Dreaded P1694 code
Having trouble with stahling issues. It will all of the sudden just stahl when driving down the road. It is like someone turned the key off. It may come right back on or it may stay off until i pull off of the road and turn the key off. When i turn the key back on it starts right up most of the time. Sometimes i have to turn the key on and off a few times. It has always started though. I pulled DTCs.
P0234 TC Overboost
P1693
P1694
I have checked all connections that i could think of. I have read all the posts in here that came up on my search and seems like alot of people have the same code but dont know if it causes and problems or not. Any ideas.
Old Oct 19, 2008 | 03:12 PM
johnh's Avatar
P0234 TC Overboost
P1693
P1694
according to my OBD2 look up tool p1694 is " no CCD message from PCM-aisin transmission
Old Oct 20, 2008 | 03:48 PM
daboocru's Avatar
That is what i have come up with as well. Not sure what that means though. Does that mean something is wrong or just a comminication problem between modules???
Old Oct 20, 2008 | 05:43 PM
daboocru's Avatar
Was told by a local mechanic that it may be a camshaft sensor that is causing the stutter and sometimes stahl. Any ideas or comments on this?
Old Oct 22, 2008 | 12:31 AM
dodgeman01's Avatar
what is the 1693 I get that a lot when I scan my truck and others?
Thanks
DM01
Old Oct 22, 2008 | 03:45 PM
OGDAWG0680's Avatar
My 01 Had The P1694 And Shortly After I Took It In And Was Told It Was The Camshaft Sensor And Had It Replaced
Old Oct 23, 2008 | 12:54 PM
daboocru's Avatar
1693 code stored in the computer
I am tryimg cam sensor tonight not real easy to get to I will post with results
Old Oct 27, 2008 | 03:47 PM
daboocru's Avatar
Installed cam sensor and still having the problem. Heard that it may be a map sensor. Called the dealer and they said no such thing on our trucks. Any ideas on what it may be.
Old Nov 4, 2008 | 11:13 PM
daboocru's Avatar
I got a new map(boost) sensor and installed it as well. NO DICE
So i took it to the dealer to have them look at it and they are telling me that it is te ECM. They want 1135 for the ecm and 300 to put it in. Seems pretty steep. Anybody have any ideas where one might be able to get one at a better price or does that sound reasonable. Thanks
Old Nov 4, 2008 | 11:48 PM
67HotRod's Avatar
The prices at the dealers around here vary allot, call several of them for a price.
Old Nov 5, 2008 | 10:06 AM
CB723's Avatar
I had 1694 and or 1693 and I found out my injector pump was bad. I replace the lift pump and injector pump. I put it in myself the parts was about $1,500
Old Nov 5, 2008 | 06:16 PM
bent valves's Avatar
P1694 – No CCD message received from ECM. This is a bus communication failure between the PCM and ECM and will set companion codes (P1693) in both.
Before spending money on a new ECM, try removing the ECM connector and check pins:
30 – Ground
40 – CCD bus –
41 – CCD bus +
Also check the PCM module connector C3 pins:
28 – CCD bus –
30 – CCD bus +
I would closely inspect those connections for crud or corrosion and try some electrical contact cleaner followed by dielectric grease.
Good luck.
Old Nov 6, 2008 | 07:57 AM
BarryG's Avatar
If needing an ecm check with auto computer exchange 500ish with a warranty. They are remans/rebuilt
http://www.autocomputerexchange.com/...ts.asp?cat=185
There are a few other places out there as well. There are couple places where you can send yours in and they will repair for less.
If they are charging 300 to install it they are out of their mind. It is 3 bolts (10mm iirc) + one for the connector(allen head). You will need some extensions but they are not that hard to get too. One on each side of the unit and one on the bottom center and then the plug screw. Might take you 1/2 an hour. When I have done it I have removed the oil dipstick tube hold down bolt (10mm) so that I can move it a bit for better access.
Old Nov 6, 2008 | 07:47 PM
ussprinceton's Avatar
Working on fixing mine this weekend. I get a 1693 code. Funny cause I just bought a PCM from autocomputerexchange for 379.00 with shipping. Got it Tuesday the 4th going to put it in on Saturday. And going to check the connections Bend Valves talked about. New to this.
Old Nov 6, 2008 | 07:53 PM
ussprinceton
Also if I disconnect the battery cables for a few minutes this should reset any codes right?
2001 cummins 5.9 91,000 miles stock.
