discrepancies between service manual and truck
Job: front crankshaft oil seal replacement.
Manual: pry out old seal use special tool to seat new seal.
Actual: dampener completely different from what is described and pictured in service manual. which would make the installation tool (if i had bought it) useless
so the damper in the service manual (purchases from Geno's) does not even come close to the damper on the truck. i was able to install the new seal but had to fabricate the tool needed out of what was available. as per the MOPAR specs in book i should have been able to do it with a piece of pipe, a block of wood, washers and said dampener bolt. nay nay nay. this does raise the question as to torque specs. book says 180 ft# but that is for a single center bolt not the 4 bolts present on the existing vehicle.
I did manage to install new seal. may have damaged it with first attempt we will see (at least i know what to do now). it leaks it leaks i guess.
My main question is to those who have bought the specs form Genoe's and other sources is this discrepancy consistent and what are the torque specs for the 4 bolt dampener.
Bookshelf
05-18-2011 04:20 PM
Smokin96_12v
10-19-2009 09:11 AM
stock03
07-05-2007 06:51 PM
jcb
01-31-2006 08:40 AM
