-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   dirty injectors (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/dirty-injectors-44058/)
02DODGE May 6, 2004 09:26 PM
dirty injectors
Is there any way to check to see if your injectors are dirty without pulling everything apart? Surely there is a simple test for this.
phox_mulder May 6, 2004 09:38 PM
You could take a lazer temp gun and measure each cylinder at the exhaust manifold.
More a test for a stuck injector than a dirty one, but there might be slight differences?
More than likely they need to be removed and visually checked, then maybe pressure pop tested.
(wrong term, but CRS'd the real term)
phox
Dr. Evil May 6, 2004 10:53 PM
phox
I thought certain cylinders can normally run a bit hotter/cooler than other cylinders???
dodgediesel4x4 May 7, 2004 12:33 AM
Dr. I was under the same impression. I thought that # 6 runs hotter than # 1, thats why most install their pyro towards the rear of the block on the manifold. I could be wrong.
