-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   diffs and transmission fluid (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/diffs-transmission-fluid-27680/)
Jun 2, 2003 12:08 PM
What gear oil is recommaned and how much do I need to change the diff fluid in both the front and rearends?
What about the manual transmission fluid?
I got 120,000 miles on my truck and I have never changed the fluids in the diffs or transmission.
HeberRam Jun 3, 2003 08:30 AM
Re:diffs and transmission fuild
Oh my Beeeeeeegeeeesays, check out these links, there is a ton of information for everyone who owns a CTD regardless of year:<br><br>http://www.dodgeram.org/tech/dsl/maint/3rd_Gen-24v.htm<br><br>http://www.dodgeram.org/tech/dsl/Facts/98ISBspecs.html<br><br>Steve
Fishcop Jun 3, 2003 08:35 PM
Re:diffs and transmission fluid
Cattle Hauler, I just changed both differencial fluids last weekend, each used just under 4qts each. I used AMSOIL 80w-90. I have the automagic tranny so I can't help ya there....... ;D
PourinDiesel Jun 5, 2003 12:15 PM
Hey Cattle Hauler,<br>Go to Auto Zone and get some 85w140 from Valvoline about 3 quarts for the front and 4 for the back (get one extra for good measure).<br>Also if you have limited slip get some Trans X limited slip fluid (you add about half a bottle per Diff).<br><br>--Justin
TXRAM2 Jun 5, 2003 01:13 PM
CH,<br>I put almost 4 quarts of the Royal Purple Max Gear 75/140 syn, in the diff. No lsd additive. Thinking of goin to the RP Max Gear 75/90 in the NV4500. I have 66000 miles on the tranny and I'm thinking it's about time to change.<br><br>wk
