Diffrence in HO and SO
Old Apr 28, 2003 | 12:20 AM
kingofdodge7131's Avatar
other than the power, whats the diffrence?
Old Apr 28, 2003 | 05:31 AM
Alan_Reagan's Avatar
Re:Diffrence in HO and SO
On the HO, injectors are smaller, pump setup/control card, the starter requires a spacer, pistons and compression ratio is higher. That's the primary differences.
Old Apr 28, 2003 | 11:56 AM
will all the boxes and performance parts still work in the ho?
Old Apr 28, 2003 | 01:27 PM
OlBlue's Avatar
Yup! Boxes and injectors and turbos, and air filters, and exhaust, and..... all work great on the HO...Can you tell I'm all ;D ;D ;D !<br><br>I put in injectors first. Seems like the common thought is HOs respond best to injector increases. I liked them!!!<br><br>In order to use extra fuel though, you need more air, so here comes a box with boost fooler (MAP sensor plugin) and boost elbow for turbo. I really like them!!!<br><br>In order to move the air, you'll need a better breathing air filter and possibly a larger exhaust. My EGTs would be 1600 without trying and filter minder pegged at 100% before the AFE Mega Cannon. Now I really really like them!!!<br><br>But, still not enough air to keep EGTs under control, so PDR HX-xx here I come.<br><br>See what a slipper slope this is??? ;D :
TooTall
17
Jun 19, 2007 10:23 PM
kingofdodge7131
Mar 3, 2003 04:45 PM
kingofdodge7131
Feb 2, 2003 11:13 AM
kingofdodge7131
Jan 28, 2003 11:15 PM
kingofdodge7131
Dec 8, 2002 06:48 AM
