Differential and Transfer Case Oils?
Old Feb 28, 2005 | 12:25 PM
hotdram's Avatar
Tried to search "differential oil" but because oil is only 3 letters, I can't and "differential" turned up to many hits, so here's my question:
If I want to change out to synthetics in my front and rear diffs and transfer case, what are my options THAT MEET Dodge specs?
Thanks,
~Rob
Old Feb 28, 2005 | 03:23 PM
mkubacak's Avatar
For the search, try the google search at the bottom of the page.
As far as synthetics, I am running Mobil 1 in the differential cases, and I believe a Quaker State ATF in the transfer case. Speaking of which, I need to change both. Not sure if they meet Dodge's specs, but I am way past warranty.
Old Feb 28, 2005 | 03:43 PM
Meatball's Avatar
castrol syntorq for the diff. because, from what i hear you need a loan to buy mobil 1. but thats jus heres-say
Old Mar 2, 2005 | 12:04 PM
Moose10's Avatar
I just put a tad over 3qts of Amsoil ATF in my t-case this weekend. Seems a bit more smooth going into 4x4 now...but was never really a problem before either
Here's a tip though...when you drain the t-case, remove the fill plug before the drain plug
Old Mar 2, 2005 | 12:15 PM
HOHN's Avatar
I use Redline D4 ATF in the t-case with good results-- very smooth shifting in and out.
For the Diffs, I use Redline 75w-90 if I can get it, otherwise whatever synthetic (valvoline, M1, etc) they have at the local parts store.
jlh
Old Mar 2, 2005 | 02:33 PM
RowJ's Avatar
In this part of the country, I prefer a synthetic 80w-140 in the differential. Not what Dodge calls for but seems quietier and smoother in hotter weather, and better protection, IMO, when towing or working your truck hard. I get a lot less "dust" or debris on my magnets with the heavier fluid.
Know of nobody that has had negative side effects with this slightly heavier gearlube.
RJ
wyododge
Aug 18, 2011 07:48 AM
eswartz
Sep 16, 2004 02:21 PM
ViperSBT
Jun 3, 2004 04:49 PM
Gordonville
14
Feb 27, 2004 07:16 PM
