Danger Boost and Danger EGT?
Normal highway driving conditions; no load, 65-70mph.
1. What's a good "rule of thumb" to keep the Boost and EGT numbers under? 2. What's aprox nrs are getting close to "danger" levels, so I should aware of if approaching? I have a Quadzilla Commander; not thrilled with it, but...that's what I have. Basic stock except for the BHAF and Raptor. |
usually depending on your truck i would say 650-750* empty maybe it all depends. max egt where i start backing off at is 1250*-1300* and my probe is pre turbo but i cant remember what is danger post turbo. my boost stops at 20psi boost no matter what. hope this helps...
Originally Posted by bpollard1248
(Post 2233050)
Not sure why my BOOST would register so high (+20)...that's without a load...:( |
I think the stock turbo shouldn't register more than 20-23psi or your wastgate might be AFU. I've got the Commander too and all I can say is that it works. Not the best, though.... I see 700-800 degrees at 70mph. I set the Commander to warn at 1250 and start to defuel at 1400, I think.
Originally Posted by sheriffav8r
(Post 2233955)
Stock turbo i would say anything over 30psi and your starting to get in the danger zone! EGTS When pulling a trailer i would say 1300 is the max that i would want to run, but its not hard on are trucks to run 1600 degrees as long as its only for a couple seconds! I peg out a 1600 pyro when pulling!
| All times are GMT -5. The time now is 07:43 AM. |
