Cruise Control whacked out
Old Oct 30, 2010 | 03:13 PM
pquevill's Avatar
The other day we were facing 60 mph rainy winds and the truck was shifting in between overdrive and 4th gear....like it was slipping. I did the reset apps and it seemed to calm it down.
Then, on the way home, the cruise control went out or never came on (light in the speedo) I tried a reset apps again and checked the vacuum lines and everything else seems in order. I have searched the forum for crusie control and nothing seems to be matching up. There is no fuse for the cruise control and would you have any suggestions to start to troubleshoot?
Thanks in advance
Pat
Old Oct 30, 2010 | 05:52 PM
johnh's Avatar
Thanks in advance
Pat
your cc is controlled by the PCM and the brake switch......it's possible the brake switch is out of adjustment or bad........... if the problem is in the PCM, it will show a code which you can retrieve if you have a scanner..........another possibility is loose or dirty connections
Old Oct 30, 2010 | 09:10 PM
pquevill's Avatar
Checked all connectors and no corrison, etc. but didn't think about the brake switch. I'll check that in the morning. Don't have a scanner at the moment. Thanks!
Old Nov 1, 2010 | 03:43 PM
SIXSLUG's Avatar
Clockspring?
Old Nov 1, 2010 | 04:18 PM
swordfish's Avatar
if the light never comes on in the odometer then it isn't the clockspring or the brakelight switch. From what I have gathered (and have not proved on my own truck as I am having the same issue) is there is more then likely a crimped or broken wire in the steering column. Take the knee knocker panel off and examine the wires to see if that is your issue. That is the only information I have been able to come up with when the light does not come on in the odometer.
Swordfish
Old Nov 2, 2010 | 05:17 PM
SIXSLUG's Avatar
Good to know.
Firstgenfanatic
Nov 8, 2009 04:05 PM
2500CTD
Jan 11, 2006 10:54 AM
Mike D
Dec 1, 2004 07:35 PM
TomW
Aug 13, 2004 01:09 PM
TexasDiesel
Dec 27, 2002 10:47 AM
