CPS Removal War: CPS 1 and John 0
Old Oct 21, 2005 | 05:54 PM
John In NC's Avatar
I did a search on crank position sensors and it didn't shed any light on how to actually remove the !@#$%^&* little bugger. I just spent the better part of three hours and all my pulling power and ended up with CPS=1, John=0 in the CPS removal war. Is there some sort of method short of a drill to remove it? On a good note the starter and dip stick were easy to remove. Shoud I hit it with a rock or something?
Old Oct 22, 2005 | 06:41 AM
j-fox's Avatar
I thing the recommended procedure it to soak it a lot, then turn it in the hole as you pull on it.
If you get the right phrase it helps.
Try this one----@%$#!&^*%#@.
Old Oct 22, 2005 | 09:09 AM
electrifried's Avatar
My mechanic changed mine, mentioned of all them he did mine was the worst by far. He resorted to drilling it, tapping it, then using a puller in the tapped hole. This is what I was told, I dont even know what one looks like.
I have a GOOD mechanic. I am thankfull for him.
Old Oct 22, 2005 | 09:14 AM
RAPTOR01's Avatar
I agree ..I like to use PB balst when I take one out thats being a pain. soak it alot and twist it around. Chris
Hammer
117
Nov 16, 2006 11:18 PM
shortround
Oct 1, 2003 06:43 PM
TPilaske
Apr 3, 2003 05:10 PM
