-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   CPS? (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/cps-18390/)
BigBlackDodge Mar 15, 2003 12:24 PM
CPS?
Truck has a &quot;lopey&quot; idle. Tachometer is not working. When tach does start to work the engine kinda bumps up a little.<br><br>Camshaft Posistioning Sensor?<br><br>Pulled code 1596 but it is not on &quot;BAT Autos&quot; code list.<br><br>
BigBlue Mar 15, 2003 02:03 PM
Re:CPS?
I wish my truck had a lopey idle. ;D The CPS may be it. I think the vehicle speed sensor or something like that, I can't remember what, would cause the tach and everything else to quit working. Is your speedo still working?
BigBlackDodge Mar 15, 2003 02:05 PM
Re:CPS?
Speedo working fine.<br><br>The Vehicle speed senor, is that the one on the OD unit?
phox_mulder Mar 15, 2003 02:35 PM
Re:CPS?
[quote author=BigBlackDodge link=board=4;threadid=12291;start=0#116338 date=1047752663]<br>Truck has a &quot;lopey&quot; idle. Tachometer is not working. When tach does start to work the engine kinda bumps up a little.<br><br>Camshaft Posistioning Sensor?<br><br>Pulled code 1596 but it is not on &quot;BAT Autos&quot; code list.<br><br>[/quote]<br><br>BAT has a &quot;light duty truck&quot; specific code list, and that is listed on there as &quot;speed control switch always high&quot;<br><br>Here's the link.<br>http://www.batauto.com/chrysler/99-01trk.shtml<br><br>Whatever that means is beyond me.<br><br>phox
BigBlackDodge Mar 16, 2003 09:04 AM
Re:CPS?
Replaced CPS last note.<br><br>Idle is smooth, tach is working.<br>Hessitation @ 30 and 50 @ low RPM is also gone.<br>Best $ 60 repair so far.
